Crow’s Nest
Designer:
Chris Hintz
Project Category:
Bookshelf Speakers
Project Level:
Beginner
Project Time:
8-20 Hours
Project Cost:
Under $100
Project Description:
I produced this center channel from what I learned on this forum. Thank you. I wanted something to put on the fireplace mantel under the TV. So space was limited. I did want the challenge to build something from scratch. So this is it. An MTM nested design with 2 Dayton TCP 115-8 woofers and a Dayton NDFA20-6 tweeter. It worked well and I am happy. I changed the schematic from the original 3.7 ohm resistor on the tweeter to a 1.5 ohm as I felt it needed to be a bit brighter. It’s the only other resistor I had laying around. That worked well.
Design Goals:
A better center channel than what I had before.
Driver Selection:
Enclosure Design:
Box has external measurements of 20″ wide x 6″ tall x 7″ deep. It is ported with two 0.75 inch ID x 2.5 inch long ports.
Tips & Tricks:
Don’t seal the box with glue until you are sure you are done.
Conclusion:
I love it. Worked out well.
About the Designer:
I am an Orthopedic Physician Assistant. I mostly build bikes in my spare time.
Project Parts List:
Part # |
Description |
Qty |
295-416 |
Dayton Audio TCP115-8 4″ Treated Paper Cone Midbass Woofer 8 Ohm |
1 |
275-030 |
Dayton Audio ND20FA-6 3/4″ Soft Dome Neodymium Tweeter |
1 |
255-212 |
Jantzen Audio 0.22mH 18 AWG Air Core Inductor Crossover Coil |
1 |
257-032 |
Dayton Audio 0.40mH 20 AWG Air Core Inductor Crossover Coil |
1 |
027-218 |
Dayton Audio PMPC-2.7 2.7uF 250V Precision Audio Capacitor |
1 |
027-212 |
Dayton Audio PMPC-1.5 1.5uF 250V Precision Audio Capacitor |
1 |
027-244 |
Dayton Audio PMPC-10 10uF 250V Precision Audio Capacitor |
1 |
004-1.5 |
Dayton Audio DNR-1.5 1.5 Ohm 10W Precision Audio Grade Resistor |
1 |
+ There are no comments
Add yours
