Flat Panels + Sub
Designer:
There are some that call me Tim
Project Category:
Freestyle Speakers
Project Level:
Beginner
Project Time:
1-8 Hours
Project Cost:
$100 – $500
Project Description:
Flat panel speakers with small subwoofer.
Design Goals:
Built for my sister’s NY apartment
Driver Selection:
Dayton Audio DAEX32EP-4 Thruster 32mm Exciter 40W 4 Ohm
Tang Band W5-1138SMF 5-1/4″ Paper Cone Subwoofer Speaker
Dayton Audio ND140-PR 5-1/4″ Aluminum Cone Passive Radiator
Enclosure Design:
24×24 Formular panels
9×9 3/4 Ash plywood cube
Crossover Design:
added 2 in-line 250uf capacitors to the flat panels to limit some of the bass
Tips & Tricks:
Used Bullseye 123 primer to seal the panels. You have to brush this on as aerosols will melt the foam. The primer can be sanded. After this, you can paint them however you like.
Conclusion:
Very happy with the sounds, especially for as little room as it takes up (wall-mounted panels)
About the Designer:
This is project #4 I think.
Project Parts List:
Thanks! As popular as Distributed Mode Loudspeakers are, you are the first I’ve seen that primed and painted them. Everyone else uses the hideous pink or tinted black finish.
