Birthday Build
Designer:
Rasmus Munk Larsen
Project Category:
Tower Speakers
Project Level:
Intermediate
Project Time:
20+ Hours
Project Cost:
$500 – $1,000
Project Description:
Here is my “Birthday Build” for my friend Mike, commissioned by his wife as a surprise present for his birthday. Mike, our wives and I love to get together to listen to music. Mike is a constant source of learning about cool artists, old and new, for us, so I really wanted to build something excellent that we could enjoy together over the years to come.
Design Goals:
My goal was to create a great sounding and beautiful floor-standing speaker, putting to use all the skill and knowledge I have accumulated over the last few years of building, experimenting, and listening to more experienced speakers designers, here on Parts Express and other online forums.
Driver Selection:
The speaker uses a Vifa XT25BG60-04 1″ Shielded Dual Ring Radiator Tweeter, and a Peerless 830875 6-1/2″ Nomex Cone HDS Woofer. I have used the Vifa XT25 in previous projects and love the very detailed and neutral sound it has. I also think it creates an incredible 3-D soundstage. I had not used the Peerless Nomex cones before, but saw many people recommending them. I am very happy with this choice as it was easy to work with, plays surprisingly deep, and looks great.
Enclosure Design:
The enclosure is a 25 liter bass reflex box tuned to 42 Hz. I simulated it in WinISD.
Enclosure Assembly:
The cabinet has 3 internal window braces, foam dampening (mattress topper) and a 3″ port made from ABS pipe, using a 60 degree knee to make it fit, and flared on the outside using a chamfer bit. The sides of the baffle have a 1/2″ roundover. The cabinet is covered in zebrawood veneer and finished with Polycril.
Crossover Design:
The crossover is adapted almost exactly from a design by Jay a.k.a. Brewski in an old thread here on Parts Express: http://techtalk.parts-express.com/forum/tech-talk-forum/45553-hi-i-am-new-and-need-advice
I used a mix of Audyn and Jantzen (the lower end ones) for the series caps and NPE for the large caps in Zobel and the RLC. Inductors were Jantzen. I added an L-pad (not shown in diagram) consisting of a 3 Ohm resistor in series and an 8 Ohm resistor in parallel to match sensitivity and reduce an upwards tilt of the tweeter response.
Conclusion:
I am very happy with the way these speakers came out, both in terms of looks and finish and sound.
About the Designer:
Rasmus is a computer scientist and amateur choral singer living in the San Francisco Bay Area. He grew up in Denmark (where all those sweet speaker drivers come from).
Project Parts List:
Part # |
Description |
Qty |
264-1092 |
Peerless 830875 6-1/2″ Nomex Cone HDS Woofer |
1 |
264-1012 |
Peerless XT25BG60-04 1″ Shielded Dual Ring Radiator Tweeter |
1 |
260-281 |
Bi-Amp Speaker Terminal Gold Binding Post |
1 |
255-104 |
Jantzen 5203 1.5mH 15 AWG P-Core Inductor |
1 |
257-022 |
Dayton Audio AC20-15 0.15mH 20 AWG Air Core Inductor Coil |
1 |
027-268 |
Jantzen 0422 2.7uF 400V Z-Standard Capacitor |
1 |
027-362 |
125uF 100V Non-Polarized Capacitor |
1 |
027-458 |
Dayton Audio DFFC-0.47 0.47uF 400V By-Pass Capacitor |
1 |
027-932 |
Jantzen 0264 10uF 400V Crosscap Capacitor |
1 |
027-940 |
Jantzen 0272 22uF 400V Crosscap Capacitor |
1 |
005-2.5 |
Mills 2.5 Ohm 12W Non-Inductive Resistor |
1 |
004-3 |
Dayton Audio DNR-3.0 3 Ohm 10W Precision Audio Grade Resistor |
1 |
004-8 |
004-8 Dayton Audio DNR-8.0 8 Ohm 10W Precision Audio Grade Resistor |
1 |
004-1.5 |
Dayton Audio DNR-1.5 1.5 Ohm 10W Precision Audio Grade Resistor |
1 |
Unable to find crossover diagram from the link.
Can you provide?
Thanks
Updated. Check it again.
Beautiful towers!!! Love the Zebra veneer here! Not sure about the crossover on the tweeter however – to many components of rather very large values – they will compromise the sound for sure. We use a Scan Speak version of this tweeter with only 5 crossover components and it is stunning!!! Cheers!
High Rasmus! Greetings from Berlin,Germany. I like your Speakers very much. Not too big and good Proportions.
I think thay sound as well as they look like. Now my Question: Are there construction -details available? Or it`s not possible to copy your project?
I have a question it looks like the crossover you are using is designed for 2 woofers (4ohm) load, your using just 1, where’s does that put your crossover point ? Around 4k?
Would you mind sharing what you did to the mtm crossover to make your tm work, I have (6) 875’s laying around with a couple pairs of r2604/8330 that need some attention, thanks, hope you get this
