DARS Cube
Designer:
GustoAudio
Project Category:
Portable Speakers
Project Level:
Intermediate
Project Time:
1-8 Hours
Project Cost:
Under $100
Project Description:
The DARS Cube is a portable speaker that’s easy on the eyes and ears.
Design Goals:
The goal was to design a portable Bluetooth speaker with a clean look that will be used mostly at low volume for long listening periods (workday).
Driver Selection:
Dayton Audio RS100-4 4″ Reference Full-Range Driver 4 Ohm
Part# 295-378
Enclosure Design:
6.5″ x 7.5″ x 6.25″
1/2 Pine Enclosure
3/4 Poplar Baffle
Metal Plate for switch, volume and 3.5mm jack
Also as speaker out connector to run additional passive speaker
Enclosure Assembly:
Mitered sides, glued and ran through the router.
Lots of sanding to bring out the wood grain.
Front Baffle was left natural and sealed with wax finish
Top/Sides and a mix gray enamel paint mixed with white stain. Weird, but looks really nice.
Crossover Design:
Full Range with -4db of baffle step compensation.
Tips & Tricks:
Used threated inserts to make removable rear panel. Makes swapping parts and adjusting much easier.
Conclusion:
Overall really like the look of this speaker. I’ve used this mostly listening to music while working. Small enough to fit on a desk and sounds great.
About the Designer:
Been wood working and messing with electronics / audio since a kid.
Project Parts List:
Part # |
Description |
Qty |
295-378 |
Dayton Audio RS100-4 4″ Reference Full-Range Driver 4 Ohm |
1 |
325-105 |
Dayton Audio KAB-250v3 2x50W Class D Audio Amplifier Board with Bluetooth 4.0 |
1 |
325-110 |
Dayton Audio KAB-FC Function Cables Package for Bluetooth Amplifier Boards |
1 |
260-406 |
Speaker Cabinet Port Tube 1-3/4″ ID x 2-1/4″ L |
1 |
Im really intrested in making this but 3d printing the case and making a cool design, where can i go about to learn how to wire all this together!!!???
