Hifi Bluetooth speaker
Designer:
Blake Nickell
Project Category:
Portable Speakers
Project Level:
Intermediate
Project Time:
8-20 Hours
Project Cost:
$100-$500
Project Description:
I call this speaker the “Mk1” since it’s my first build. Feel very happy about this build. So let me know what you guys think! All but a few parts were sourced from you guys @ partsexpress!
Design Goals:
Initially, I was wanting to make a bass heavy bluetooth speaker, which don’t get me wrong I definitely did. But in the end, I feel like I’ve made a high-end HiFi Bluetooth speaker. Again let me know what you all think!
Driver Selection:
See Parts List
Enclosure Design:
All enclosures are sealed. Subwoofer enclosure is a .23cbft. Had to double baffle the bottom to fit the 8″ passive down firing. L/R channel I put together. Roughly .06 cbft. For sound deadening. Subwoofer is lined with 1/8″ closed cell foam & the L/R channels have a patch of 1/4″ open cell foam on the back wall, 1/2 open cell strips on the side walls with a little polyfill stuffed around the corners.
Enclosure Assembly:
Sub box used Titebond II and 1.25″ brad nails. L/R boxes were clamped and glued with Titebond II & screwed into the side of the subwoofer enclosure.
Crossover Design:
This build requires 0 crossovers thanks to the TPS3116D2 amplifier board.
Tips & Tricks:
Take you’re time. Measure twice, even 3 times, cut once.
Conclusion:
I am very impressed with this build to say the least, although it is my first. The clean and crisp clarity is unlike any Bluetooth speaker I’ve listened to before. Also the loudest I’ve heard, the mids/highs get so loud indoors it hurts and I think it honestly has ridiculous bass output for a Bluetooth speaker. Tuned around 25hz, things on my walls shake. All in all I absolutely love this build. Very loud outdoors too.
About the Designer:
Been into speakers/audio since before I can remember. Finally built my own speaker. I’m only 19 and this is my first build.
Project Parts List:
Part#DescriptionQty.
264-917Tang Band W5-1138SMF 5-1/4″ Paper Cone Subwoofer Speaker1
295-492Dayton Audio DS215-PR 8″ Designer Series Passive Radiator1
295-590Dayton Audio DMA105-4 4″ Dual Magnet Aluminum Cone Full-Range Driver 4 Ohm2
320-635 TPS3116D2 Class D 2.1 Bluetooth 5.0 Amplifier Board 2 x 50W + 100W with Filter and Volume Controls1
325-212 Dayton Audio LBB-5v2 5 x 26650 Lithium Battery Charger Board/Module 21V with Charge Protection1
142-109PKCELL 5-Pack 26650 5000mAh Li-Ion Flat Top Rechargeable Battery1
260-7710 Penn-Elcom 9145 Rubber Cabinet Foot 1.5″ Dia. x 1.5″ H4
260-765Speaker Cabinet Carpet Covering Charcoal Yard 54″ WideN/A
300-5002Knock-Down MDF 0.23 ft³ Mini Bookshelf Cabinet1
+ There are no comments
Add yours
