Plate Amp Replacement
Designer:
DIY GUY
Project Category:
Amplifiers
Project Level:
Beginner
Project Time:
1-8 Hours
Project Cost:
$100 – $500
Project Description:
Alternate plate-amp replacement to OEM
Half the cost of OEM (with coupon)
Design Goals:
Replacement of Subwoofer Amp Plate
Enclosure Assembly:
Axiom EP350 Subwoofer
Tips & Tricks:
Two 3/4″ cuts on each side of the width
Pre-drill the mounting screw holes and mission accomplished………………………………………….Red/Black Anderson Powerpole Connectors
used between amp & subwoofer
Conclusion:
Good option from Parts Express
About the Designer:
DIY
Project Parts List:
Part # |
Description |
Qty |
300-803 |
Dayton Audio SPA250 250 Watt Subwoofer Plate Amplifier |
1 |
That’s awesome. I bought a Rockville rock Crusher 10in subwoofer and the speaker and plate amplifier where so under par . I already replaced the speaker with a Rockford Fosgate prime and the sound quality is 500% better. Now I ordered the SPA250 to replace that cheap amp. I’m lucky that it will fit into this cabnet perfect. The ohms of the original speaker was 3.8 and Rockford Fosgate was 4 ohm . I can’t wait to hear what a difference the Dayton plate will make. Thanks for reading.
I think what you did is awesome. I’m doing basically the same thing. I purchased a 10in Rockville Rock Crusher home sub. The sound quality out of the box was so bad. No low bass , bad distortion at any kind of volume. So first thing I did was buy a Rockford Fosgate Prime. That alone improved the sound quality 500%. Since the cheap speaker I removed was 3.8 ohm, the 4 ohm Rockford Fosgate was a good match. Now I’m ordering a SPA250. Can’t wait to hear the difference. Thanks for reading.
