The Vagrant Monitor
Designer: Jay1
Project Time: 20 hours
Project Complexity: Amateur
Project Cost: $200
Driver Selection
Woofer selection is a Peerless SDS-160F25PR01-08, the tweeter is a Vifa TC7FD- 4. After seeing a set of outstanding frequency response and distortion measurements on the tiny Vifa I was very curious to try one out as a tweeter. Knowing this little full range driver was capable of crossing much lower then any dome tweeter my woofer selection allowed for a true woofer. Staying with the budget theme of the Vifa I settled on the Peerless with its high xmax and solid sealed box performance in a compact cabinet.
Enclosure Design
The box is a very simple and fairly compact sealed monitor with one quirk. The woofer is placed 1/2″ in front of the tweeter which allowed me to easily use 2nd order slopes for the crossover. I simply ran the edge of the double baffle piece through my table saw with the blade cocked 45 degrees, and then glued it over the woofer cutout. All drivers are surface mounted, as their frames allow. The box is constructed out of 1/2″ MDF, 13″ H x 9″ W x 8.5″ D. The cabinet is separated internally half way between the woofer and tweeter. Each chamber is fully stuffed with polyfill.
This speaker features a 2nd order LR at 1000 hz crossover. Given the budget nature of the design I tried to keep the crossover as simple as possible. Even using all Dayton poly caps a pair of parts should only come out in the mid $30 range per speaker. Impedance makes for a very easy load, this is true 8 ohm design. Speaker sensitivity is low at 82 db, but given the capable woofer they can easily handle a 100 watt amp. The measurements shown are not a reflection of sensitivity.
(This is the measured on axis response shown with the reverse null. Below 500hz should be ignored. This is not actual sensitivity)
About The Designer
I’ve been a speaker enthusiast since 2001 and a die hard DIYer since 2011. I am 31 years old and married with a kid. I am an aircraft maintainer for the USAF specializing in structural, composite, outer mold line repairs.
Project Parts List
Part # |
Description |
Qty |
264-1146 |
1 |
264-1144 |
1 |
027-434 |
1 |
004-3 |
Dayton Audio DNR-3.0 3 Ohm 10W Precision Audio Grade Resistor |
1 |
255-044 |
Jantzen Audio 0.80mH 20 AWG Air Core Inductor Crossover Coil |
1 |
266-568 |
1 |
027-420 |
1 |
004-2.4 |
Dayton Audio DNR-2.4 2.4 Ohm 10W Precision Audio Grade Resistor |
1 |
255-032 |
Jantzen Audio 0.40mH 20 AWG Air Core Inductor Crossover Coil |
1 |
260-283 |
1 |
260-317 |
Acousta-Stuf Polyfill Speaker Cabinet Sound Damping Material 1 lb. Bag |
1 |
260-540 |
Parts Express Speaker Gasketing Tape 1/8″ x 3/8″ x 50 ft. Roll |
1 |
Add all available items for this project to
your cart on www.parts-express.com with one click of the mouse!
If you wish to add or remove products from this
projects parts list, you can do so any time in your
Parts Express shopping cart before completing your order.
+ There are no comments
Add yours
