38 hz tapped horn
Designer:
nickc
Project Category:
Subwoofers
Project Level:
Intermediate
Project Time:
1-8 Hours
Project Cost:
Under $100
Project Description:
this is a tapped horn designed by volvotreter. it uses a tang band 1139 and has great response down to 35 hz. total cost for me was about 75 dollars.
Design Goals:
loud deep bass on the cheap.
Driver Selection:
264-919 Tang Band W6-1139SIF 6-1/2″ Paper Cone Subwoofer Speaker
Enclosure Design:
designed by volvotreter, go check out his page he has many cool horn projects.
Enclosure Assembly:
only used half a sheet of mdf. painted with whatever white paint i had lying around.
Crossover Design:
low pass filter on amp
Tips & Tricks:
cut all the pieces accurately. this is more complicated than a ported box and the pieces have to be precise.
Conclusion:
i couldnt be more happy with this sub, not boomy at all. ive thrown everything i have at it from jimi hendrix to some old school bass testers just to see what it could do. it can play it all with ease.
About the Designer:
designed by volvotreter. he has a webpage.
awesome build! what kind of glue did you use?
I built this a couple of days ago. I used 3/4” birch ply with maple veneer. Absolutely phenomenal results. I’ve got it hooked to a 2.1 system on my TV. The bass is huge but it’s also very natural sounding. People talking sound natural but when it’s an action scene or a concert, look out. The bass is massive but smooth. I need to build one (or two) for my car now.
Hmm.. I build this design with the same tang band 1139 (even tried the neo magnet version) but discovered way too much air noise from the back of the driver frame. The vent holes in the steel frame are just not large enough for quiet operation at medium to full excursion. Will be trying two different Wavecor drivers and an SB Acoustics one that fit the box. Not many options left to fit the 7″ wide inside panel. The box design is good though, I feel.
Hi Herman, curious if you had better success with other drivers for your tapped horn or were you able to solve the air noise problem another way? Thank you.
Do you need to stuff this with polyfill?
I would line the internal walls with light absorption because without anything, there is way too much air noise. Huffing puffing.
