Arborea Sealed
Arborea Sealed bookshelf speaker design by, CKay
“I have built a few designs through the years, but this is my first ground up design.“
Project Level: Intermediate
Project Time: 20+ Hours
Project Cost: $500 – $1,000
Project Description: Sealed two-way satellites and sealed powered subwoofer designed for two channel listening.
Design Goals:
Deliver a neutral midrange with low distortion.
Maintain wide, even dispersion for stable imaging and soundstage depth.
Provide a clean sealed low‑frequency roll‑off for seamless subwoofer integration.
Achieve tight, controlled bass with excellent transient accuracy.
Minimize cabinet coloration through strategic bracing of the enclosure.
Driver Selection: GRS 10PR-8 10″ Poly Cone Rubber Surround Woofer – GRS Part # 292-421 – Model: 10PR-8
Enclosure Design: – Satellites 0.35 ft3 sealed – Subwoofer 0.55 ft3 sealed
Enclosure Assembly: The enclosures were constructed from solid walnut that was split and rejoined to reduce warping/cracking. An internal cross brace was used to minimize panel resonance and 1/2in sonic barrier along with medium stuffing was used to damp reflections.
Crossover Design: 4th order acoustic at 2.15kHz, 2nd order electrical low pass and 3rd order electrical high pass.
| Part # | Description |
| 275-131 | Dayton Audio RST28A-4 1-1/8″ Reference Aluminum Dome |
| 295-654 | Dayton Audio SIG180-4 6.5” Signature Woofer |
| 295-164 | Dayton Audio MX10-22 10″ Max-X High Excursion DVC Subwoofer |
| 300-806 | Dayton Audio SPA300-D 300 Watt Class-D Subwoofer Plate Amplifier |
Conclusion: I was pleased with the overall neutrality of the sound as well as the bass extension with the subwoofer. I was able to get 30hz extension in room and good integration between the sub and satellites at 80hz.
+ There are no comments
Add yours
