Perfection One
Designer:
Vaheed
Project Category:
Tower Speakers
Project Level:
Intermediate
Project Time:
20+ Hours
Project Cost:
Over $1,000
Project Description:
Project is about building a set of 3-way stereo speakers, as the name suggests they had to be perfect in everyway and I believe they are.
Design Goals:
The project has a “No Compromise” criteria, I wanted a detailed, natural sound on a sealed design to minimize the delay with 25hz-20khz extension at -+3dB
Driver Selection:
High frequency driver:
Morel CAT 308 1-1/8″ Soft Dome Tweeter (#277-082)
Mid frequency driver:
Morel TiCW 638Nd Titanium Series (#297-105)
Low Frequency driver:
Dayton Audio UM12-22 Ultimax (#295-512)
Enclosure Design:
To minimize the delay I chose the sealed design, Low frequency driver is sealed in the main enclosure and mid frequency is also sealed in another enclosure inside the main.
Enclosures are massive and heavy, each one weights closer to 400 lbs. Material used is 1″ MDF everywhere, tons of internal bracing with sluts and wave guides plus 3″ front baffles.
Enclosure Assembly:
I’ve only used glue and no screws. on joints I’ve used Titebond 3 and for layering, I’ve used Titebond melamine glue.
I’ve also used multiple layers of Bitumin paper and Melamine glue for vibration dampening everywhere and ofcourse pre-modelled extensive insulation.
Crossover Design:
It is an active dual mono 3-way crossover design.
Tips & Tricks:
Project was a huge success. I am very much happy with the results, Literature reviews took 3 months, design phase took 2 months and construction phase took another ~4 months.
Speakers are detailed and fast, base extension is lower than 25hz +-3dB in my living room, mid frequencies are to die for and high frequencies are silky and smooth, you simply can not stop listening to them.
About the Designer:
I am crafty and have experience in wood working.
This was my first serious speaker building project.
1. Do you have a build thread of this speakers and can you link to it?
2. Why is all the area inside the speaker filled in completely, and how does this work?
3. What amp drives the big subs?
Thanks! 🙂
Thanks for your comment,
No speakers dont have a build thread.
I don’t understand your second question, do you mean why it is filled with insulation? Or bracing?!
Each driver is driven by a channel of Behringer A500 (3 units, 6 channels total)
You need better amplification on your mids and tweets. I have an A500 and use it solely for woofer duty. That thing stinks in the stereo imaging department. My Yamaha AVR blows it out of the water in every conceivable way except absolute power.
I don’t agree, I believe Stereo imaging is not an amp characteristics. My only reason to upgrade the amps would be more power, Ultimaxs are not efficient drivers.
I don’t know how these sound, but they look super cool 🙂
No doubts in my mind these are spectacular performers. Nicely done my good man!
Congratulations they look great and I love your choice of drivers, I’m a huge Morel fan and the Behringer A500’s should give you more than enough power, (though aren’t a Yamaha avr!). I’m sure they sound amazing! Thank you for sharing.
