Pure Audio Project Trio 15
Designer:
Park
Project Category:
Tower Speakers
Project Level:
Intermediate
Project Time:
8-20 Hours
Project Cost:
$500 – $1,000
Project Description:
The PAP audio trio series of open baffle speakers.
Design Goals:
Use left over parts and great drivers.
Driver Selection:
Dayton Audio P220
Eminence Alpha 15a
Enclosure Design:
Open baffle
Enclosure Assembly:
Easy and straight to point
Crossover Design:
Using an electronic crossover with drivers xo ‘ ed st 200 hz with a 12 db roll off.
Tips & Tricks:
This was an Pproved build from PAP with their design and metal bar bracing.
Conclusion:
Great speaker, super imaging, easy to build and perfect for any room.
About the Designer:
I build therefor I am.
Project Parts List:
Part # |
Description |
Qty |
295-346 |
Dayton Audio PS220-8 8″ Point Source Full-Range Neo Driver |
2 |
290-407 |
Eminence Alpha-15A 15″ Driver |
4 |
Fantastic woodwork on that baffle! Looks gorgeous.
What are dimensions of the baffle? I know that the Eminence Alphas are the favourite driver due to high Qts (hence low mass corner), but will the relatively narrow baffle lead to an early baffle roll off?
I was just at Axpona and heard the Trio 15 Horn1 with the Whammerdyne tube amp. It sounded fantastic. How does your implememtaion compare to the Trio 15TB as that model uses the full range driver? I would like to build something similar.
What did you use to make the metal frame in the back to hold the wood?
Wonderful. This is the project I was looking for. How can you get the dimensions of the OB and the assembly diagram of the crossover?
Hi>>> Would you kindly reply/email/inform me MORE details of the crossover……Which equipment did you used? How did you tweak/program that equipment.
Regards,
Nick
I would greatly appreciate a parts list so I could diy
A passive crossover
Where did you get the metal frames…did you make them? Care to share?
