Three-way Towers (TwT)
Designer:
Raymund Berlo
Project Category:
Tower Speakers
Project Level:
Intermediate
Project Time:
8-20 Hours
Project Cost:
$500 – $1,000
Project Description:
Three-way towers for bedroom. I like the detail in planar speakers and I’ve used this dome mid before and liked it. Though I should try a combination of the two.
Design Goals:
Tower speakers for music and movies. Good dynamic response and clear detail. Solid bass response down to below 40Hz. Will build a sub later for lower frequencies. The tweeters had to end up a t a specific listening height as the vertical dispersion is limited on these.
Driver Selection:
Dayton Audio DSA270-8 Woofers
Dayton Audio RS52AN-8 Mids
Dayton Audio PT2C-8 Tweeters
Enclosure Design:
Rear slot ported tower tuned to 37Hz
Enclosure Assembly:
.75″ mdf glued
vinyl wrapped
lined with .5″ sound damping foam
Crossover Design:
Dayton Audio XO3W-625/5K
custom series notch filter and L-pad circuit on midrange
100W L-pad attenuator on tweeter
Tips & Tricks:
Cabinet construction was pretty straightforward. Tall tower with rear low port. No separate enclosures were needed for the mid & tweets as they have sealed backs.
Conclusion:
This was the first 3 way setup I’ve done in a long time so I was expecting a little trial and error with tuning. One if the reasons I used an L-pad attenuator on the tweeter.
After initial listening and checking with the RTA I was able to determine this would benefit from a series notch filter on the mid-range as the resonance was less than an octave from the crossover frequency. This made the vocals more balanced and detailed. One day I may just make full custom crossovers for these.
Post woofer break-in these have great detail with music and incredible dynamic range with movies.
About the Designer:
Went to school for audio engineering 25+years ago. Still like to do projects when the opportunity arises.
Project Parts List:
Would you be willing to share some details about your project? I think these might be exactly what my brother is looking for. Thanks!
I really need to get here more often. What kind of details are you looking for?
Hello Ray. Great build. I am looking to build LCR speakers using the same tweeter/mid but different woofers. Can you help me design that? I am a woodworker but not a speaker-builder. Thanks.
I really enjoy this mid/ tweeter combo. I later ended up swapping the woofers with a B&C neo driver. I was able to remove the L-pad on the mid as the B&C woofer was far more efficient.
