4×6 Guitar Cabinet
Designer:Mike Grobusky
Project Category
Guitar and Bass Speakers
Project Level
Intermediate
Project Time
1-8 Hours
Project Cost
$100 – $500
Project Description
Guitar cabinet. 4 x 6.5 with Eminence
Design Goals
Small, portable, killer tone
Driver Selection
Eminence 6-1/2″ Guitar Speaker 20W 4 Ohm
Enclosure Design
Sealed cabinet
Enclosure Assembly
3/4 baffle, 1/2 sides birch plywood, back is 5/8 particle board
inverted slant front baffle
Conclusion
Note. Speakers wired in series. Total cabinet is 16 ohms. Best suited for tube amplifiers up to 50 watts.
About the Designer
Played guitar for 40 years. Retired sound system engineer.
Project Parts List
Part # |
Description |
Qty |
299-402 |
4 |
From the builder. The cabinet is 12 in deep, 17 1/2 in by 21 in. The front baffle is inset 1 inch is slanted inward 10 degrees. Used some fiberglass insulation, not stuffed. Has 1/4 in jack and banana type inputs. Weight is 28 pounds.
Mike, I was/am planning a similar project to use with a home brew stack. IE 2 x 4 x 6.5 bottoms. How does your cab compare sonically to any other cab you may have used?
THE Keith Richards? Nice band!. I like the closed back designs much better than open back. Not as loud, but much tighter, especially bass notes and full chords are clearer. I play at church, so don’t need 110db. I have used a Blackstar 5h, a Hughes & Kettner 18w, and just trying out a Peavy ValveKing 6505 (20W). Another nice feature is you can orient it tall or on side, and stack 2 easy enough. Compared to a dual 12 in cab ported with JBL K120’s which is quite a bit louder system.
What do you think about using this with a orange micro dark terror?
How do you get a total cab load of 16 Ohms with 4 x 4 Ohm speakers?
4 x 4 = 16 SERIES HE SAID ALREADY
