Azure Storms
Designer: Strandt
Project Time: 20+ hours
Project Complexity: Hobbyist
Project Cost: Under $100
Driver Selection
I used a Goldwood GT-1005 Pezio tweeter which has a great sound after adding a 27 ohm resistor. 5 x Sony 5″ woofers which I was lucky enough to find in Parts Express speaker buyout section
Enclosure Design
The enclosure is 4 feet, 2 inches tall. 9 inches wide, and only 6 inches deep, resting on a base that adds 3 inches on each side for stability.
The pezio tweeter has a 3khz bass stopper, the top 3 woofers are in series with no crossover. Finally, the bottom 2 woofers are in series with a 900hz low pass crossover, to boost the low frequency response of the enclosure. the final Ohms of the enclosure is 6.25
Enclosure Assembly
The entire enclosure was built using nothing other than a dremmel tool, and glued together with a few supporting nails.
Conclusion
The final results of this project were really impressive. When I began this project, I had no idea the final results would sound so accurate. Vocals sound fantastic! And the bass response does not need a subwoofer for support. I have built many more expensive speaker projects prior to building the Azure Storms, but this was by far the best sounding speaker I have made
About The Designer
Dan Strandt has been selling home audio and designing home theater systems for over 5 years. Unhappy with the quality and/or price of speakers avalible in retail stores, he began building his own. Eventually Dan wants to make a career of custom speaker design.
Project Parts List
Part # |
Description |
Qty |
270-011 |
1 |
266-215 |
1 |
+ There are no comments
Add yours
