Blast Box 200 Watt Portable Bluetooth Speaker Kit
Designer:
Tom Wilson
Project Category:
Portable Speakers
Project Level:
Beginner
Project Time:
1-8 Hours
Project Cost:
$100 – $500
Project Description:
Great Portable Sound
Design Goals:
Clean, simple execution
Driver Selection:
Stock drivers from PE kit Part # 300-7162
Enclosure Assembly:
Easy assembly. The kit is well machined and easy to build.
Crossover Design:
Stock design from PE kit Part # 300-7162
Tips & Tricks:
Two coats black spray primer + two coats black textured metallic spray paint. I carefully cut thin black mat board to create a gasket between the clear acrylic control plate and the wood recess. Used 1/2″ extruded polystyrene corner guards. Replacement amp handle. Speaker grilles. Rubber feet.
Conclusion:
Very good kit, fun to build, SOUNDS AMAZING!
About the Designer:
Tinkerer, old stereo and speaker restorer, music lover.
Project Parts List:
Beautiful work. I looked at the amp for my project and will come back to it for this application.
My friend I do something similar any sugestion where I found the 1/2″ extruded polystyrene corner guards
What did you use for a handle? I haven’t been able to source one I like.
