Dayton Audio Point Souce Monolith
Designer:
Park
Project Category:
Tower Speakers
Project Level:
Beginner
Project Time:
8-20 Hours
Project Cost:
$100 – $500
Project Description:
Monolith – open baffle Dayton Audio point source 8 with 3 – 8inch subs to bring up the xo point.
Design Goals:
Simple build, pick drives that were easily accessible to others.
Driver Selection:
Dayton Audio Point Source 8 Part # 295-346
GR Research 8 inch subs, PEQ 370 amplifier
Products Used:
Dayton Audio 8 Part # 295-346
PE binding posts
any 8 inch subs with plate amplifier
Enclosure Design:
Basic baltic birch flat baffle with side supports
Enclosure Assembly:
One inch baltic birch with legs
Crossover Design:
None, but I built modified amp/rca high pass filers specific to my amplifiers ohm rating.
Tips & Tricks:
Take your time.
Conclusion:
Great combination of drivers with the ability through the plate amp to bring the lower woofer up to meet the ob full range driver.
About the Designer:
I get bored, love to build, then sell, then build something else..
This is clearly not the right description for this build. Looks like it was duplicated from the previous entry somehow.
Project should indicate NOT a ZOB, but a custom built OB with the Dayton Audio 8 inch FR driver. Includes three GR Research subs, but any of the the 8 inch subs that can reach 200 hz should do fine.
This is an open baffle design which results in phase cancellation in the bass frequencies. The effect is a 6dB per octave bass roll off from around 300Hz. This why boxes are used – to stop the rear radiation cancelling the front radiation. Open baffle can be used for mid+ but with appropriately sized baffle. However room phase cancellation remains an issue.
