The Portable Hulk
Designer:
Redneckjap
Project Category:
Portable Speakers
Project Level:
Intermediate
Project Time:
8-20 Hours
Project Cost:
$100 – $500
Project Description:
Portable, rechargeable, Bluetooth speaker system
Design Goals:
The primary design goal that I had was to make a portable Bluetooth speaker just to “see if I could do it”. Of course, I wanted the end result to sound better than any $40 speaker that can be bought at discount stores.
Driver Selection:
295-549, 295-417, 275-022
Enclosure Design:
At first, I was going to build a sealed design (and probably should have for the sake of size) but decided to add a passive radiator. I used two Dayton Audio GF180-4 6.5” woofers and the Dayton Audio DSA215 8” passive radiator tuned to approximately 40hz. Installed in approximately 2.5 cu ft.
Enclosure Assembly:
I may regret it, but I used some leftover shelving boards for the cabinet construction. Once I assembled the wood and completed cutouts, I took it to a local truck shop and had it coated with Line-X bed liner.
Crossover Design:
I purchased a ready-built 3,500 hz crossover that seems to work ok for these drivers.
Tips & Tricks:
Hone your soldering skills! Use plenty of glue on your wood joints.
Conclusion:
I probably need to attenuate the tweeters slightly because they do seem to overtake the system, but I must say the for a first attempt, this thing ROCKS!
About the Designer:
Just a hobbyist that enjoys learning.
Project Parts List:
Part # |
Description |
Qty |
295-549 |
Dayton Audio DSA215-PR 8″ Designer Series Aluminum Cone Passive Radiator |
1 |
295-417 |
Dayton Audio GF180-4 6-1/2″ Glass Fiber Cone Woofer 4 Ohm |
1 |
275-022 |
Dayton Audio TD25F-4 1″ Soft Dome Tweeter 4 Ohm |
1 |
Here is the amplifier section: https://www.parts-express.com/2-x-100W-Bluetooth-5.0-TDA7498-Amplifier-Board-with-Micro-SD-Card-Reader-24-to-30-VDC-320-638
Here is the charger kit: https://www.parts-express.com/Dayton-Audio-LBB-5v2-5-x-26650-Lithium-Battery-Charger-Board-Module-21V-with-Charge-Protecti-325-212
Light kit: https://www.parts-express.com/Dayton-Audio-LBB-5CL-DC-Charging-Power-Cables-and-LED-Light-Kit-for-LBB-5-and-LBB-5S-Batter-325-142
Batteries: https://www.parts-express.com/5-Pack-26650-5000mAh-Li-Ion-Flat-Top-Rechargeable-Battery-142-107
love that you used a passive radiator though I certainly would have liked a picture showing it.
left a note liking the fact of a passive radiator being used and was wondering if it got posted and how do you keep the curious fingers away from your cones?
@Dan Still, Sorry i havent responded…I didnt realize you had commented. Anyway, i should have used two passive radiators, not one! As for curious fingers, i dont have any of those around my house, however, you could easily install covers to protect the drivers, i just chose not to. I am now actually thinking about modifying this and taking the 8″ passive radiator out and installing a new 8″ subwoofer and change the amplifier out to a 2.1 version. 😀
